G40 Won't Start. Help pls
Hi all,
My G won't start at the moment. Any help would be amazing as it's due to go in for MOT in a couple of days!
Here's what I do know: Battery is fully charged and seems fine. when I turn the key, the dashboard lights come on, as does the radio. I can also turn the headlights on etc.
However, it won't start. I can't hear a solanoid click or starter motor etc.
I HAVE been able to bump start it no probs.
Could it be that a fuse or a relay has gone? (my amateur diagnosis)
This is extra weird, as it's been running really nicely, no probs at all for the past few weeks.
Any help would be very much appreciated.
Cheers,
Tim
  • Views 905
near the inlet there should be a plug with a black red wire that goes to the starter ....see if that has 12v when the key is on crank , confirm theres 12v to the fat red on the starter at all times , check the earth cables are tight and sound
other than that it sounds like the starter ...you could bench test it with some jump leads
does it have an imobilser ?   could be that too
Edited by steveo3002
Probably just corrosion of the contact surfaces on the above-mentioned starter solenoid connection. Unplug, clean a little, reconnect, normal service resumes.
Thanks guys. will check both these.
If anyone else has any more ideas I'd like to hear from you.
its got to be one of the above really....basicly its wires with a motor on the end
either the wire isnt supplying power or the motor has stopped working , 10 mins to diagnose with a test lamp
