Cigarette lighter replacement
Hey. I want to convert my cig lighter to a USB port. Curious whether the power to it is allways on or only when the ignition is on. I’m not sure whether to get ones with lights or a voltmeter on as I don’t want to drain battery when not in use. thanks!
  • Views 797
You can test it. Try the cig lighter with the ignition off. My USB port also lights up, but only with the ignition on. If it has a seperate positive connector for the lighting you should connect it to the same circuit. I actually connected my positive to the positive wire of my rear defroster, so I can flick the defroster switch and be 100% sure it doesn't dain the battery. My defroster doesn't do anything though 🙂 , might get too hot when you run it for too long
Thanks. I will give it a teat then. The switch idea is a good one. I might have to copy you haha. Cheers
