Lupo/Polo Clock Wiring Pinout
As title suggests, I'm after the pin out for a lupo 1L E pre canbus, but I'm sure a pre canbus polo 1.4 with the round clocks will be the same.
I'm sure somebody has done it or can point me in the right direction to another thread somewhere.
  • Views 4.3k
32-pin connection (vehicle identification no. 6X)
1 -Terminal 15, positive
2 -Right turn signal warning lamp
3 -E. speedometer output
4 -Not assigned
5 -Fuel gauge sender
6 -Airbag
7 -Sensor earth, terminal 31
8 -Coolant temperature sender
9 -Terminal 31, earth
10 -Oil pressure switch, high
11 -Speed signal
12 -Alternator warning lamp, terminal 61
13 -Glow period warning lamp or catalytic converter monitor warning lamp → Note
14 -Rear fog light warning lamp
15 -Not assigned
16 -Not assigned
17 -Main beam warning lamp, terminal 56a
18 -Left turn signal warning lamp
19 -Anti-lock brake system (ABS)
20 -Dash panel insert illumination, terminal 58d
21 -Driver door open signal
22 -Coolant shortage indicator
23 -Terminal 30, positive
24 -Terminal 31, earth
25 -Self-diagnosis, K wire
26 -Right parking light
27 -Left parking light
28 -E. speedometer input
29 -Brakes general
30 -S-contact
31 -Seat belt
32 -Side light warning lamp or exhaust emissions warning lamp → Note
1) Is assigned depending on engine fitted or specific country equipment
That's the pinout for a canbus polo/lupo so no good to me. Cheers anyway.
X
X
No it's not the CAN-Bus ones are the 6E designation and the CAN-Bus is on the other 32 pin connector
32-pin connection, green (vehicle identification no. 6E)
5 -EPS (electromechanical power steering) → Note
15 -EPC → Note
19 -CAN high
20 -CAN low
25 -Reset
26 -Ambient temperature → Note
27 -CAN high external
28 -CAN low external
32-pin connection, blue (vehicle identification no. 6E)
4 -Not assigned
6 -Airbag
11 -Speed signal
15 -Not assigned
16 -Rear lid
23 -Terminal 30, clock
29 -Brakes general
30 -S-contact
31 -Seat belt
15 -EPC → Note
19 -CAN high
20 -CAN low
25 -Reset
4 -Not assigned
6 -Airbag
11 -Speed signal
15 -Not assigned
16 -Rear lid
29 -Brakes general
30 -S-contact
31 -Seat belt
I'm trying to swap GTI clocks in, and it's lighting up like a christmas tree. oil pressure buzzer and light on even though it's fine. no speedo, and no rev counter. I have both green and blue plugs in my clocks but my green plug has 3  only wires.
My blue plug is obviously missing a few as well. Looking like I need to get the mulitmeter out.
X
