8P Gearbox on an AAU engine
I would be grateful of any advice reference fitting an 8P gearbox onto a 94 1.0 AAU bready. Firstly would I need to carry out any modifications to mounts etc or is this just a straight forward swap and can I use the stock driveshafts from the original box.I understand I will need a replacement  ARB due to the 5th gear but apart from that I’m unsure so any advice on this would be much appreciated! Many thanks. Rich.
  • Views 717
Popular Days
late car so will have the correct arb
you need the 5 speed mount with the box , id suggest you fit a new clutch kit at the same time and minimum of selector shaft seal and new oil ...or all seals if funds allow
