Anti roll bar removal MOT failure?
Right so got my MOT is coming up for my 6n2 1.4 8v. Previous garage said the car was too low to get on the ramps but mentioned the roll bar that's been removed (by previous owner). After reading many mixed things online I deiced to remove the remaining brackets and drop links leaving no evidence of there ever being one. I don't know how true this it by I've heard not all models ever came with one. So my question is has anybody been in the same situation and passed their MOT?
  • Views 6.2k
Looking at motester.co.uk
 anti-roll bar counts as a suspension component
  • a suspension component 'missing, likely to become detached or directional stability impaired' is a Dangerous Fail
  • a suspension component 'with an unsafe modification' is a Major Fail
  • a suspension component  'modified so that the suspension is inoperative or likely to fail other components' is a Dangerous Fail
If  too low for Roller Break Test a road test is possible, but not, of course with Major or Dangerous fail found.
Dangerous Fail is 'do not drive until repaired' on the MOT VT30 form.
Ah damn thanks for the reply
No, an ARB is not a requirement.
A stabiliser bar is, though - but if you remove that then you won't be driving to the MoT in the first place..
