6N2 ignition live wire
Hi everyone i'm new here.
Does anybody know what the ignition live wire is for the 6n2 in the heater unit?
I also have a picture attached to this thread.
Thanks everyone in advance
  • Views 1k
First Welcome to the forum.
The supply wire is the Black/Blue wire (2.5mm) on pin 2 of the 6 pin plug, it's fed from fuse # 49 (25amp)
Hey nige8021 thanks for your answer.
I have connected the + and - to the 12v outlet wires and now i have a third wire that needs to be wired to the ignition. So if i read this correct i can use that wire on the Black/Blue one?
The Blue/Black is an ignition ON only supply it comes via the "X contact relief relay"
Thanks for your quick replies!
This solved my problem.
