MK2F Central Locking
Howdy
I've ordered a central locking unit and I am starting to try to figure out a clean way to run the cables inside the door.
Has anyone (willing to share) done this before?
I would need to run a couple extra wires in there for the future as I want door speakers and maybe even electric windows eventually :fool:
  • Views 560
If you are purchasing the cable separately, rather than buying a kit of parts, I would suggest that you purchase more flexible cable (thinner strands, but more of them) - at least for the part that passes through the rubber boot between the door and the pillar.
If you use standard cable in this area, it is likely to soon fail due to repeated opening and closing of the door
Regards
