Fuel Sender Unit
Hi,
Looking for advice on sourcing a fuel sender unit.
My fuel gauge has never worked and the fuel sender unit was pretty badly rusted to the side of the tank when I've had a look.
I've freed this and cleaned it up where possible, though the fuel gauge is now reading over the limit? Think this is beyond repair.
Does anyone know where I might be able to source this? I can't find anything online that I know will work but my knowledge isnt the best!
Danny
  • Views 841
Or the float is jammed or stuck in the ‘tank full’ position.
If you disconnect the wiring from the sender does the gauge drop? If so it proves the issue is with the sender.
