Fuse box multi plug
Reassembled. Let there be dipped light.
it works.
Just as well. Still waiting for the terminal block from Latvia. It was processed quickly.
  • Replies 26
  • Views 2.9k
  • In the Autodata wiring, Yellow/Black is Left Headlight from fuse#7 and the Right headlight is just Yellow no stripe from fuse 8
  • Just a thought, have the relays got back EMF protection diodes across the coil ? as if that went short circuit the current draw would go crazy (but might not blow the fuse) and if that connector was i
  • A loose connection causes high resistance in a circuit, which in turn creates heat.If the fuse is the correct rating, hasn’t blown and you’ve  not overdone it with the lamp wattages, I’d guess this is
When the new part arrives you’ll take one look at dismantling that connector to fit the new one and say ‘nah, I’ll leave it as it is’ 😀
As the saying goes, If it ain’t broke, don’t fix it😉
