Hi all.
Yesterday I was driving my VW Polo Classic 1.7 Diesel year 2000 and all of sudden it lost acceleration. Accelerator pedal was unresponsive even when I pushed it all the way down. Car is moving slowly and I can shift gears but accelerator pedal is not doing its function. When I turn off the car and start it again, all is working fine and 5 minutes later same thing happens. I read somewhere that this is "limp mode" but I'm not sure. There are no lights on the dashboard. What could be the cause of this ?
  • Views 961
You will need to get the fault codes read with a VAG specific reader ideally VCDS as it's a 2000 oil burner it' isn't EOBD compliant (2005 for oil burners) that is why it needs to be a VAG specific, not all fault codes will put on the warning light, once you have the code/s post them and then we can start the fault finding
TDI or SDI?
2 hours ago, Yeti said:
TDI or SDI?
It is SDI
My stab in the dark would be the EGR valved coked up, but your best option, as Nige says, is to give it a scan and see what it says.
