Twin headlamps to single
I have a mk2 coupe S with twin headlamps. I am wanting to change to single headlamps. Can I use the same outer lamps and remove the inners or do I need to swap them all out? Would I be best to upgrade the loom while I'm at it? The originals are not great.
Boab
  • Views 524
  • steveo3002
    steveo3002
    just remove the spots ...the outers are already dip/main   yes a loom /relay upgrade is a wise move
Cheers for the speedy response. Is the upgraded loom easy to fit?
yes should be plug and play , maybe some wires to tidy up if you use a universal one
dont forget to unplug the resistor up near the fuse box....small tube looking thing with yellow wires
