Digifant ECU question - Polo GT
Hi,
Does anyone know about the differences between Digifant ECUs? I'm looking for Polo GT parts.
So far, I have found part no. 0261200306 / 030906022k on eBay with one seller in the UK. This should be the OEM part, I think.
What I'm wondering is, are there any other variants that work? Like, is it just a case of the different model codes being for different mounting brackets or some nonsense like that? I'm going to have to come up with a way of mounting it anyway, so who cares, if I can get a cheaper ECU I might as well.
  • Views 850
i have some im about to list over the weekend ..whats the number you need
i think thyere all interchangeable , at least one early one has no 02 input
Literally looking for something that can run a Mk3 GT injector setup 🙂
For a project car so some modification can happen if I need to change pinouts and stuff.
needs to be a gt one then....if youre asking if a spi or random vw ecu can do it no not really
regarding the other thread seeking mpi parts
any mk2f can yield the fuel pipes , lift pump and its wiring , rear pump cradle (pump idealy needs upgrading still) , exhaust mani  , that opens up the searching a bit more
i did this exact swap on my mk2...not easy sourcing the whole kit now
Edited by steveo3002
