Windscreed washers not working
My MOT is up in the next few days and thought I should finally get this fixed, washers don't work I pull back on the stock or forward for back ones and nothing I have checked fuses there fine a few weeks ago I played around with washer pump and got it working but only briefly and stopped working the next day. Any suggestions would be greatly appreciated thanks.
  • Views 804
if fiddling with the pump made it work maybe suggests a loose or corroded connector
this is basic trouble shooting .. you need a multimeter or test lamp to check for 12v at the connector when pressing the stalk , then  use some scrap wire to wire the pump directly to a 12v car battery and see if it works
