air leak
Hi. i have a 1990 vw polo 1.3 saloon. for years it ran rough, kept cutting out etc. i think the original carb was the pierberg which i understand was problematic. i got a new weber last year but it's still not running as well as i expected £500 later. its lumpy. when you're doing 30 in 4th it judders. that smooths out if you pull the choke out a bit. somebody suggested an air leak. please does anybody have any ideas?
  • Views 426
is it mounted via the original style rubber base?  they can fail often
otherwise good check round that the fixing are tight , any vac hoses are in good order etc
thanks for your reply. not sure. any idea where i could get a quality replacement base in case it is that?
