Advise / info for new Polo Breadvan owner?
Hi there. All being well I should be picking up a tidy MK2 Polo Breadvan I am buying in the next couple of weeks. I really like the look of these and that they are something a bit different you don't see very often. There's certainly some nice ones featured here on this forum.
I'm pretty used to working on / owning older cars in general, but I was hoping to pick up any tips you might have for a VW and MK2 Polo virgin!
So any info on the following would be helpful:
- Recommendations for parts suppliers
- Common problems
- Club events / VW meetups
- Anything else you think might be useful to know
Thanks.
  • Replies 8
  • Views 926
  • steveo3002
    steveo3002
    cambs here too   rust is the biggest problem ...have a good look all around , rusted filler neck on the fuel tank is very common , as is rust holes under the battery   brakes can f
  • From the FAQ.   I'd probably add Gearbox selector shaft can leak. Old globe headlights are dim when there's someone with Xenons or LEDs behind you.  P45T halogen bulbs and a r
  • steveo3002
    steveo3002
    look at the center of the headlamp glass , later ones will have h4 molded onto the glass so that means "modern" halogen , if it doesnt have h4 then id look around for some used lamps then you have a w
cambs here too
brakes can feel rather poor so i would suggest a good refurbish all around , parts are cheap so no excuse
parts ...best get the part number and search online  i tend to find nearly all my stuff on ebay , try and choose a good brand name if you can
From the FAQ.
I'd probably add
  • Gearbox selector shaft can leak.
  • Old globe headlights are dim when there's someone with Xenons or LEDs behind you.  P45T halogen bulbs and a relay switched headlight loom helps a lot. Plus new 14v alternator regulator and starter cables and earths dramatically.
  • Seat bolster driver side goes floppy.
  • Door membranes can get leaky giving wet carpets.
  • Carburettor rubber mount can be a vacuum leak.
No social this year, but previous have ranged from a bit loud and crazy to chillaxed.
Parts
German ebay or maxrpm.de, but watch for Brexit import customs fees.
I've used Carparts4less (slower and less choice, but same firm  as ECP) and Autodoc recently.
AWS Spares are generally good.
GSF used to be good, but disappointing quality last time I tried.
Vehicle Wiring Products,
Frost ART ltd.
VW Heritage are all good but somewhat pricey.
look at the center of the headlamp glass , later ones will have h4 molded onto the glass so that means "modern" halogen , if it doesnt have h4 then id look around for some used lamps then you have a wider choice of improved bulbs
a relay harness will make a huge improvement to the light output
Thanks, lots of tips there I appreciate it. I'll check out the 'FAQ' as well. Even though I know they can be a pain I'm quite looking forward to getting to grips with a car without fuel injection, see if I can remember all the old skills!
The one I'm looking at is only a 1 litre and I've had much faster cars before but this is all about stepping back in time a bit and getting back to a bit of simple motoring. The trouble I've found with later 90s cars is the ECUs and various other electronic bits are all starting to break down and some are impossible to get hold of. At least with something a bit simpler if a part is not available I can try and work out how to fix it. That's the plan anyway 😅
hah i converted mine to fuel injection lol
not wrong about 90s electrics though
Get a Haynes manual too. I’ve found it to be of great help so far even with just understanding what components are and how things work.
Yes love a good Haynes manual. That's another thing you don't find so easily for newer cars. I'll get one off eBay. I think Haynes manual division got bought out and are stopping all their printed manuals and going completely 'digital' soon. All well and good but unless they produce a version that works offline that's no use if you're broken down in the middle of nowhere!
Yes, I think you can get one easily for less than a tenner, so well worth it. I’m tempted to buy another to keep in the car too. Actually, you can get a version for your phone that you can access “offline”. I have a copy for the Mk2f kept on my phone.
