2002 1.2L 3 cylinder clutch problem
The clutch has failed think its air in the system. Had fluid changed and system bleed. No loss of fluid but if not used for 4 or 5 days the peddle seems to go to the floor and the clutch won't allow you to select a gear. Not sure if its a slave or master cylinder problem. Any advice welcome.
  • Views 426
Just an update, I bleed the slave and there was air in it. Have ordered new slave in the hope that it's the seal gone in side.
Was there any hydraulic fluid on outside of that slave cylinder?
Wipe it clean, wrap a tissue around it overnight.
See if it is dry or wet. If dry the leak is elsewhere.
Thank you for the advice, I will try that tomorrow.
