G40 - Hesitancy / Misfire 1500rpm-2k COLD only
See my clubg40 post:
Hesitancy / Misfire 1500rpm-2k COLD only (polog40.co.uk)
Fairly stock G40 which when cold, first 2miles or so, produces a real hesitancy around 1500-2k.
Higher rpm's seem to sort it - like it's forcing the engine to fix itself.
Warm engine sorts it too.
This leads me to thinking it would be the blue temp sender as that is temp dependant, but it isn't.
To my knowledge spark side is ok: Coil - Cap - Arm - Leads - Plugs
  • Views 975
  • steveo3002
    steveo3002
    does the rev counter do anything wierd when its happening?  hall sender usually makes it go wild    could try another ebay dizzy....part ending AB from  a 6n will work and not too much money
Note idle is fine hot or cold.
can check the ohms on the blue sender easy enough
is it a chug chug type of rich issue or a obvious misfire?
Blue temp is fine as I said in original post.
It's a lack of power, like for a second or less I have no fuel or spark - which creates a hesitancy more so than a misfire.
Only when cold is what is mystifing me - or is it a sign of hall sendor
could try another ebay dizzy....part ending AB from  a 6n will work and not too much money for a used genuine one
See my G40 thread
Problem solved - a dodgy spark plug!
Rev counter was fine - never did anything weird.
