Selling up car and parts, no idea what anything's worth anymore
Hello everyone.
I've come to the bitter conclusion that it's time to give up the polo and parts I have after 9 years.
She's a 1993 Mk2F Tornado Red (cough - pink - cough) Genesis 1.3 AAV.
Might as well start with the bad:
- sunroof leaks and arms are rusted through
- front wings are rusted
- dent under the passenger front light
- boot lock was disassembled and thrown away by previous owner. Boot now opens with a pull cord by drivers head.
- MOT advisories => front coil springs corroded/ both front suspension arms corroded but not seriously weakened/ rear axle corroded/ front discs worn but not excessively corroded/ both front brake hoses have slight corrosion to ferrule
-Been stood for a year, no use
- Typical red paint gone pink, comes up nice with a polish though
- One of the radio wires decided to burn out and would need replacing
- Gearbox leaks, think its the selector shaft seal
- 1 month MOT left
And now the good, maybe:
- New fuel tank. Seams sealed with tiger seal then primed with raptor expoxy and finished with gravitex.
- Top end was replaced with a GT head and cam, was skimmed/cleaned/new guides. New headgasket at the same time
- Front seats replaced with Corrado seats
- Front brake copper lines replaced last year
- Clutch has about 15k use, new cable installed as well
- Usual Genesis additions. Black carpet, black door cards, black parcel shelf(needs a new cord though), split rear seats, rev counter clocks, fancy steering wheel
- Rear suspension is H&R Cup Kit 35mm drop springs and shocks. Was a complete kit but never got round to doing the fronts.
- Front brakes are 6N vented
- Rear brake hoses were replaced with braided, Goodridge I think
- Nice fat grey dealer book with loads of receipts
Now for the parts list, probably forgetting most:
- Complete NZ EFI setup. Loom/dizzy/coil/2xECU/Manifold/Fuel rail/Injectors (new seals and filters)/ISV and associated water pipe with mount/airbox and pipe/throttle body
- K&N panel filter for NZ/GT airbox
- Fancy black and silver VW logo rocker cover.
- Golf throttlebody and K&N cone. TB was setup for GT, I assume it'd work for the NZ. Comes with K&N cleaning kit too
- Large bore exhaust cat back. Probably an ebay special one. Has twin exit pipe
- G40 exhaust manifold and gutted cat.
- Spare AAV head, probably needs skimming.
- H&R cup kit 35mm front coils and springs. Got new febi topmounts to go with them too.
- 2x new lower suspension arms
- ARB block kit from PPP
- G40 front brake setup. Would need assembly
- Braided front brake hoses to go with G40 front brake setup. Goodridge I think
- Misc spare parts. Non rev counter clocks/complete heater motor and rad/service items/lambda probe/set of front lights/grill with broken tabs/6N sport tailpipe/2x standard centre exhaust pipe
I'm sure there's more parts but nothing that sticks out.
It's been a tough decision but I've realised I'll never be healthy enough to work on her again.
Any comments or advice would be greatly appreciated.
Many thanks
Edited by Acoylite
  • 2 years later...
  • Views 708
On 07/10/2021 at 13:29, Acoylite said:
Hello everyone.
- 1 month MOT left
Many thanks
Where about in the country are you please. Also can you send me some pictures of the car in question..
