78MK1 Polo Window Regulators
Hi,
Can anyone point me in the direction of a pair of manual window regulators, both windows wind up to within 5mm then the handle starts to slip, maybe this can be fixed im just not sure
  • Views 831
It might have just dropped out of alignment a bit. The quick, rough way of re-aligning is to loosen the bolts that hold the linkage into the door very slightly, so the linkage is still held in place back and forwards, but can slip a little in it's mounting holes. Wind the window all the way up and keep a little pressure on the handle while you re-tighten the bolts.
It won't cure a knackered linkage, but it's a decent bodge.
Cheers, ill give it a go.
Is it possible to get parts for the MK1, im struggling to get alot of bits, window seals, chrome bits
