polo 6n 16v high erratic idle
polo 6n 16v 3dr blue
Vag number: 030 906 030 E
ECU: MARELLI 1AV  2230
original brought the car and it drove perfectly however the throttle would stick at 1500 before dropping when rev'd, the issue is throttle body clogged had this issue on my gti, cleaned throttle body out and deleted egr pipe to stop further blockages.
however now the car idles erratically 2000-3500 rpm on idle
seemed like it needed a tba or had a air leak, smoke tested car three times and there is 0 leaks
using a genuine copy of ross techs VCDS (at my work) tried to tba however 098 shows no units, tried with Bosch esi-tronic aswell as snap on but no luck. adapting throttle in
have tested coolant temp, throttle body, wirring between ecu and throttle body, coolant temp sensor, map sensor wirring. via autodata specs
have also swapped the ecu for a second hand one but no difference.
have lived with this issue for 6 months now 10k miles and no closer to fixing it
p.S unplugging the throttle body makes the engine run fine but with higher fuel consumption and no cold start.
any suggestion would be greatly appreciated as am running out of options, have read through all the old forum posts on this issue over and over with little actual fixes.
I cannot provide a VCDS code read out due to it is on a work computer, but can take a picture and write it up if needed.
  • Views 636
Would love to know if you ever found out what the issue was? I'm having the same with mu 9n.
have fixed this issue with mine, there was two issues 1. air leak on the egr. 2. there was a damaged bit of wirring the reference voltage for the potentiometer was shorting on the power for the throttle motor (controlled by ecu)
the damaged wire was in the bit of the loom  where it goes to battery.
