Breadvan tyre suspension options
Hi I'm looking for advice on best size tyre for 13 inch bbs mesh on 40 mm lowered front and back pics be great of setups and sizes on 13 inch wheels and 40 mm suspension drop thanks
  • Views 538
I used a mixture of tyres on my mk2 bv, rubbing on the rear is your main enemy due to the flat arches, so you will need to measure the clearance you have either side of your wheels, depending on the width and offset of the wheels the clearance can be altered by using spacers or changing to a higher offset wheel. You should be fairly safe with sizes like 155/70 and 165/65. Hope this helps.
