Fault code reader
Hi, can someone recommend a fault code reader for a 2005 VW Polo 1.2 9n?
I'm looking for something cost effective so can't afford VAGCOM VCDS.
I only want something that will help me diagnose errors so don't need anything to unlock options etc.
  • Views 729
  • VCDS Lite (freeware) plus suitable FT232 cable (£20 tops, many cheaper available).   Most handheld/standalone readers will be nearly as much or more, with far less capability.   De
Depends a bit if you have a windows laptop available to put the software on, and/or if you want something that sits permanently in the glovebox for 'on the (side of the) road' checking/reading.
What problem(s) are you trying to solve?
