Squealing brakes
Hi, I wonder if anyone can help please? I have squealing brakes on my mk4 polo 1.2s. It's only when braking down to standstill. The pads and discs have been replaced. I have been told it's cheap shoes causing it. I haven't had the shoes replaced in the 8 years I have owned it. I am fed up of paying to gave them stripped and cleaned only for the problem to return. Any ideas?
Thanks, Sue
  • Views 1.2k
  • steveo3002
    steveo3002
    how quickly does it return? does the car get regular use ?   its somewhat normal they need a strip and clean once a year or so ..our focus does it every couple of years    cheap fr
  • mk2tastic
    mk2tastic
    If you are talking shoes, do you mean the rears are squealing  after having the front discs and pads replaced?
  • steveo3002
    steveo3002
    does it get regular use ? or stands around alot
cheap friction materials can also do it
if youre sure theyre not worn out you can ignore it if you wish
Just away atm but think the front pads and discs were done..would just need to check.
It's used regularly..short journeys mainly
