Carb to air pan studs
Hi guys, jus a quickie, anyone know the part number (or where I can get it) for the little brass studs that attach the air pan to the carb. Mine are snapped. Ta in advance for any help.
Deano.
  • Views 488
  • nige8021
    nige8021
    https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1982-9/1/129-12010/   https://volkswagen.7zap.com/en/rdw/polo+derby+vento-ind/po/1982-9/1/129-12060/ doesn't look like they are available as
  • They'll be an M4 or M5 at a guess, so in the orst csae, just get some long brass machine screws If you're going to use steel ones (I wouldn't, and I'm a complete bodge artist), smother them in grease
They'll be an M4 or M5 at a guess, so in the orst csae, just get some long brass machine screws If you're going to use steel ones (I wouldn't, and I'm a complete bodge artist), smother them in grease because of steel to aluminium corrosion.
Edited by Yeti
