No spark or fuel pump
So my GT has decided to stop running and when I went to start trouble shooting found no spark and that the fuel pump doesn't prime.
I've got 12v at the coil and have been through and check the distributor, and had the hall sensor checked all is well there.
The ECU replay clicks when ignition is turned on but fuel pump one doesn't even with a new relay, but have power at all the correct wires on the relay block for both.
At this point I'm pretty confused so any help is appreciated.
  • Views 445
how did you check the hall sender
