Mk2f breadvan 1991
Hi guys and first post
so I did the start motor plus inlet gasket and throttle flange and later realised the lambada sensor had come unscrewed but by that time I thought the ht leads were wrong so I swapped two round and heard a loud pop! 😮😮  before I touched Ht leads with the lambada sensor lose it ran rough and misfire (think it’s down to that anyway? ) now the poor thing will hardly start.  Wondering if any u guys know wtf is going on?
cheer
jamie
  • Views 570
The lambda sensor wouldn't cause a misfire, but it sounds to me like at the very least your ignition leads might be in the wrong order.
But let us get it straight - so it was running rough and potentially misfiring before you changed the starter, inlet gasket and throttle flange rubber?
