6n1 bonnet gas struts
Hi does anyone know of any places that do bonnet gas strut kit for 6n1 polo's? I've found a few bit they've been out of stock for a long time. Thanks
  • Replies 9
  • Views 963
  • The lower mount picked up on the wing mounting bolt, I did end up drilling a second hole as the bracket was flexing a bit and the other end went into the hinge mounting bolt replaced with a ball end b
They sell various brackets as well, I bought mine from them
Ah ill have to take a look how did you set yours up did you have to drill anything?
The lower mount picked up on the wing mounting bolt, I did end up drilling a second hole as the bracket was flexing a bit and the other end went into the hinge mounting bolt replaced with a ball end bolt from the same place
Not too bad ill have to get the parts in and give it a go thanks for the help
Hi sorry to ask again my struts and brackets have turned up which wing bolt did you end up putting the bracket on? Thanks
It was 10 years ago but I seem to recall removing the forward mounting bolt from the hinge and replacing that with a ball ended bolt then attached the strut and found a bolt for the wing that lined up so that with the normal bonnet stay in position the strut was under a bit of compression
Thanks for the info ill have a crack at it this weekend. Thanks
