oil issues, possibly very urgent ABD
These last couple of days my ABD engine has started to suffer from what I think is liquid oil somehow seeping to the intake.
There's oil tracing back into my air filter, and oil leaking from the top cover (I'm sure this isn't the right name), to the electrical pins (i think causing an electrical malfunction?)
Once i cleaned it the car started first try but it gets really oily quickly, it may be overfilled due to a mistake of mine in the past so i'll be patching up that problem as soon as possible.
as an extra note, the oil sensor (low pressure i believe) wire was chopped off and done a cheap fix (fill it with electrical tape), could that be related too?
  • Views 472
  • I went ahead and took the wiring loom out and found a lot of damaged wires, fixed them with the little knowledge i had. When i went to check the injector one of it's poles was broken off so i rep
if you over filled the oil then its most likley the problem
When i went to check the injector one of it's poles was broken off so i replaced it with one i had at hand in the garage and swapped two tubes locations, the car seems to be running fine now without any oil smelling issues.
