Mk2f GT fuel pressure regulator
Needing some advice as research is coming up blank.
I am in need of some help finding the part number of compatible fuel pressure regulators for a mk2f GT. 1992 Or any which will work fine.
Got some symptoms which suggest it may have failed. Car won't rev past 2k without bogging down or fuel supply seeming like it's being irregular.
New inline pump , have tried 2 now.
New dizzy and ignition timing set.
Ignition coils and leads changed.
Plugs checked
Blue sensor fine checked resistance
Maf checked, tps checked.
All fine but stalls out after 2k or putting foot down when idling.
  • Views 472
pressure tester are £15 on ebay...could confirm its the fault before buying
Got one ordered , will test it at the weekend, should it be 3bar or more ? Can't quite remember
yeah around 3 bar i think
