Can I richen my mix mk2f gt.
So I went to start my car this morning And found once it came off cold start it struggled to run. I know the car has always run a bit lean so I'm thinking that it was just not rich enough to run in the cold air. So is there a way to richen up the mixture.
  • Views 369
anti tamper bung on the air flow meter is covering a screw you can turn to alter it , or more advanced mess with the spring tension inside the air flow meter , best to only fiddle with it on a gas tester machine
