Camshaft & Ignition timing
If you struggle to set the camshaft and ignition timing on a SOHC or DOHC engine spare a thought for the guys setting the timing up on this 😳
14 cylinder air cooled aero engine
  • Views 668
If it's old enough twin-prop design, get it timed up, then set about doing the engine for the other wing, which rotates the opposite way.
