Polo 9N check engine light not showing on ignition
i have a 2004 polo 9N engine code AWY and i just noticed that the check engine light not showing on ignition and the fuel economy is getting worst. I know that the engine was replaced before i bought it and by the looks of it could  be a BBM, so could it be something to do with the ecu and how could i test it ?
  • Views 1.4k
The LED behind the fault light may have been obscured by something to hide a problem.
A VCDS scan will be helpful to read stored fault codes. VCDS Lite, the freeware version is sufficient,  with a suitable FTDI cable which can be obtained cheaply.
I already have a cable ordered but it will take another month to get here
  • 1 year later...
Hello! Please could you tell if the engine swap from AWY to BBM needs any upgrades of the pins or firmware of VDO (or VDO itself)
