Rear washer feed pipe leak
My 2014 polos rear washer stopped working over the cold winter period.  I eventually traced the fault to (what i assume) is a leak in the feed pipe behind the rear wheel.  When its activated a pool appears under the boot beside the passenger side wheel.
I have tried to find the pipe to fix the leak.  I have removed the wheel arch liner and also the internal facias within the boot to locate it but no luck - I can only see the wiring looms and I'd hope the feed pipe isn't in amongst them!
Any advice on where to go next?  otherwise its free money to the dealer!
  • Views 473
It may well be bundled in with the wiring loom, I'd say.
Thanks - seems crazy but possible I guess.
