Higher viscosity shock fluid
Hi everyone,
My Polo is lowered on only lowering springs. Over some bumps and undulations the car is very bouncy and sometimes scrapes with a passenger in the front.
I'm wondering if I could get some higher viscosity fluid for the shocks to see if this would give the overall effect of a "coilover" and hopefully stiffen the suspension up.
Has anyone done this on a 2F? and which fluid did you use? I will be taking it to a garage to get this done as I don't want to mess it up myself.
Thanks everyone!
  • Views 462
4 hours ago, dvderlm said:
How old are the shock absorbers?
Article on doing this in general. Does not sound worthwhile given garage labour cost if the strut can even be refilled...
https://grassrootsmotorsports.com/articles/can-you-upgrade-your-dampers-replacing-oil-inside/
Why not save up and get some gas performance shocks?
https://www.ebay.co.uk/itm/285143765217
Those gas ones look great!
If my thinking is right then it would effectively be a coilover paired with my lowering springs?
My springs are ST ones so there shouldn't be a problem with them not fitting with the new shocks.
Thanks for sending me the link, didn't even know something like that existed!
