Need help fixing dashboard lights
I have these lights on my dash and need help on where to look on what could be wrong with the car if you have any ideas or solutions please share ๐Ÿ™‚
The red-blinking car brakes are working fine.
Airbag- I don't know how to reset it because it was removed to access the dash
ABS- doesn't workย
ย
My car info:ย
VW polo 1998 3 door 1.4 Gasoline engine with 44kW
  • Views 831
  • (O!) is the handbrake. There's probably a microswitch at the handbrake lever. If this has become loose its plunger will be out, so the switch thinks the handbrake is 'On'.ย
Edited by dvderlm
  2. Tap Permissions โ†’ Notifications.
