AAU clocks mk2f
Good morning,
I've got a 93 mk2f running an ABD, it's on original clocks. I've found a set of clocks with a rev counter from a 93 1.0 aau. Any reason these wouldn't be a straight swap?
  • Views 713
Popular Days
Should be fine.
Rev counter from red/black wire on ignition coil.
Speedo drive from gearbox.
Edge connector is physically the same.
Would need to consult a wiring diagram to check if there any more sensors than on a 1.0, but if so it'd be something unimportant like washer fluid low(?) or handbrake on.
