Ignition Switch Replacement
Hi , is it much of a job to replace the , plug on the back of the ignition switch , I have a problem with the engine not cranking and I suspect the plug is the culprit .
  • Views 414
Popular Days
The contact unit? Not bad to be fair, you might have to drill some shear bolts out though. You can hotwire the car fairly easily as a diagnostic test if you pull the plug off the back of the barrel.
