Polo GT 3F ecu limp mode
Hi all, polo GT - what happens if the engine stalls with the blue temp sensor off and I accidentally restarted the engine with it unplugged (it didn’t really manage to start just coughed and stalled again) but I read here it goes into ‘limp mode’ - how do I clear this if it has??
https://www.clubpolo.co.uk/topic/109802-how-to-set-the-ignition-timing-and-idle/
  • Views 374
On a GT, the moment the blue temp sender is unplugged, it stores a fault code.
The easiest way is to clear any codes with software or code reader.  I believe the ECU does eventually clear fault codes in time.
Do you have access to a laptop?  I use VCDS lite and a cheap ebay cable to clear fault codes.
