drivers door central locking issues
afternoon folks got a slight issue , with a mk5 6r 2012 5door central locking issue
door was a replacement after a side graze , the replacement door i believe i believe was from a 2014 5 door same paint code .also rear offside was replaced to which was sweet .
now the drivers door doesnt lock with fob but all other doors do including rear offside which was a direct fit card trim etc .locks with key fine as had to use old lock from original door ,also to note doors does not lock from inside on the switch . does anyone know if there is possibly an obvious cause after replacing doors all harness matched and window switch is good on all windows just driver door wont respond to lock unlock with fob .
head buster..
much appreciated in advance hope everyone is well
swayze
  • Views 315
also mirror heater and directional switch are working 👍
