Engine starts, immediately cuts off.
Engine fires up immediately on turning key, then in 1 second cuts off clean, as if key was turned off.
No previous symptoms or problems.
I would appreciate any advice.
  • Replies 9
  • Views 913
  • That is the classic symptoms of the immobiliser cutting in and stopping the engine. Have you tried another key if you have one ? also have you dropped the key ? as that might of broken the immobiliser
  • mr brightside
    mr brightside
    I meant what year and body shape, (eg. 1991 2F), but i think you've got a bit to be going on above.
What model of Polo is it?
1.4litre 16 valve. Polo Match
That is the classic symptoms of the immobiliser cutting in and stopping the engine. Have you tried another key if you have one ? also have you dropped the key ? as that might of broken the immobiliser chip in the key also make sure that you don’t have too many other keys on the same keyring as that can shield the signal between the key and the reader
Year 2001 Mk3 3door
Thanks for your reply.
I think you are probably spot on with your reply.
No known damage to the key, but I will check anything that could be preventing the communication between key chip and the other part of the immobiliser system.
Thanks again for your reply.
Thanks for this information❤️
Did you fix the problem? If so how did you fix it? Thanks
