6n2 Polo swap
Greetings!!
I embarked on this project 1.8T swap on a 6n2 polo... Going to share this project along the way.
Engines removal
Edited by strobe
  • Replies 13
  • Views 1.3k
  • Removing Polo's wiring Removing polo's ECU essencials and ecu peripherals. Also removing fused protected power and a set of +5VDC and GNDs that power engine sensors. ECU peripherals ECU essencials T
Components painting
Intake
1000003665
Starter motor
1000002348
1000002299
Power steering pump
Power steering pump painted
Throttle body
Throttle body painted
Edited by strobe
Going to post engines removal again, imgur has failed and I can't edit the post...
Engines removal
Arriving of the donor car
Removal of the 1.8T
1.8T removal
Removing the 1.0l mpi
Polo 1.0l mpi removal
Sending donor car to scrap
1000001032
Edited by strobe
Wire harness
Staying with the harness set for the ecu essencials and ecu peripherals
1000005836
Stripping
Separating the breaker circuit and alot of the interior conections.
1000005843
1000005837
1000005839
1000005840
1000005838
IMG_20241106_221817
Engine mounts
Got the engine mounts from a seller on ebay. Gearbox mount came with the wrong dimensions so I had to take some material out for it to fit. Lower mount is also not looking good, I think it's also wrong, seller told me he doesn't see a problem, but it's there, you can see the dogbone mount is not aligned. I'll have to maybe get a spacer or something for it.
Side mount
1000001615
1000006327
Gearbox mount
1000001613
Lower mount
1000003386
1000003430
Engine in place
1000001723
ECU peripherals
Removing polo's wiring
ECU essencials
This was paired with my speeduino, so I had to remove both.
1000003337
1000003516
Fused protected
This cables go to the inside of the car some are fused others not. VSS (vehicle speed sensor) is here. Injectors +12VDC fused cable is here. A spare +12VDC is also here and ignition protection, also +12VDC. A good set of +5VDC and GNDs are here also, all going to be inhibited.
1000006116
1000006122
Removing Polo's wiring (more photos)
1000003746
1000003776
Clutch Pedal
I decided to use the clutch pedal from the donor car. I have to take the center trim off to gain access. Luckily the polo bring already two bolt mounts that align with the donor's clutch pedal, from the golf 4 and the holes made for the oil fitting from the pedal cylinder. I only have to figure the top mount. Either I cut the pedal or I cut the firewall. I haven't decided. I ordered the adapters for the oil lines. And I still have to order and mount the reservoir.
Center trim removal
1000006351
Clutch pedal mounts
1000006622
1000006623
Top Mount that need to be solved
1000006621
Fittings
1000006339
Mounting the intercooler
Position
1000006694
Cutting the shock bar
1000006695
1000007171
Cutting
1000007321
1000007324
  • 4 months later...
Fittings for the clutch pedal and clutch piston, still need to make the hose and buy the reservoir
1000010536
Powersteering hose .had to purchase a new bolt old one was to short because of the new banjo
1000010419
Work on the hoses
c
1000010251
Plan was to order edpm hose for water and some air system and nbr hose for a little end of the power steering suppply hose which has a good oem routing all until the end where it meets the pump.
1000010254
Passing the harness!
Had to remove the pins from the connector
1000010329
1000010325
1000010263
1000010265
1000010286
1000010285
