6n alternator issues
Good morning, so my issue is my 1.4 auto 6n polo isn't charging, after a very sparky jump start a few weeks ago a few things got a bit hot and melty, the main fuse fried and I suspected the alternator took a battering, so I replaced the alternator with a new unit replaced the main fuse (alternator) and charged the battery .. on refitting .. I'm getting 12.4v off the battery and when I run the car I take a hit to just over 11 .. not the juicy 13 - 14v I was expecting .. is there anything obvious I am missing? im fairly sure the 12v regulator is part of the alternator, alternator is fitted as it should be with correct tension etc .. am out of ideas.
many thanks in advance
  • Views 267
Does the battery light come on when you turn on ignition?
If it is 3 years or older take the battery for a deep discharge test. I suspect one cell is not doing its job.
