LED festoon bulb
Can anyone suggest or recommend an LED interior festoon bulb for Mk2 Polo?
Preferably warm white not blue, and bright as the original incandescent.
  • Views 322
  • https://ebay.us/m/XvgN9E I’ve used these in my Ibiza, Octavia, Touareg and now my A6
  • An LED can outlast a car. The Xenon bulbs in a 23 year old Octavia Mk1 L&K are also still working. I’m considering getting some LED units to replace the Xenon’s in my A6 from this company HIDS
Great thanks.
Er many size choices. Is a 239 bulb 39mm long?
I don't trust the AI search answer...
Guessing 35mm, so the 36mm will fit.
If you look at the second picture in the advert the length is based on the tip to tip length
So the 39mm would be tip to tip not the length of the illuminated section of the bulb 👍
HIDS DIRECT Store
No image preview
D-Lumina D1S D2S D3S D4S D5S D8S LED Bulbs, 20000LM 120W...
D-LUMINA D1S D2S D3S D4S D5S D8S LED headlight bulbs are made of high-quality extremely bright LED, 6500K Xenon White, 20000 Lumens high brightness per bulb, +500% brighter than standard xenon bulbs.
