Steering pump for 2002 Polo
My power steering has failed which turns out to be the pump on my 2002 1.2 polo. Brand new I have been quoted £410 inc vat which is silly money. Can anyone tell me a reliable source for cheaper, recondition ec with at least a 2 year guarantee please ?
Would something like this be reasonable ? https://www.ebay.co.uk/itm/196251958751?_trkparms=ni_actn%3Anav%7Cni_nt%3AWATCHITM_GTC%7Cni_apos%3A1%7Cni_group%3Afalse%7Cni_sg%3A1%7Cni_pos%3A1%7Cni_st%3ANEW%7Cni_wh%3A1%7Cni_nid%3A816407957612%7Cni_nsid%3A196251958751%7Cni_bn%3A1&_trksid=p2380424.m570.l5997
The only thing is it was £170 yesterday and now it is £190
  • Replies 10
  • Views 427
Have you checked (yourself) that the strip fuse for it in the fusebox above the battery is not cracked?
Might save you a lot of money and wasted time to do that check.
Take a clear well focused photo if you're not sure, and post it here.
There isn't a fuse near the battery for this model, only in the dash fuse box. The mechanic did however look in the battery when checking and would have spotted it.
Edited by marb67
Are you sure there isn't something that looks like this under the topmost plastic cover?
Edited by Pete1
According to the dealers workshop manual there are two fuses for the power steering system and both are on the top of the battery one is a strip fuse as @Pete1 mentioned and the other is a normal cartridge type
if the fuses are ok then have a look for Stevens VW Dismantlers as they normally have good stock of used parts however it won’t come with a two year warranty that you mentioned I think you’ll have to buy a brand new one to get that sort of warranty
IMG_9804.jpegIgnore that comment about both fuses being on the battery it’s only the 50 amp pump supply that’s on the battery the control fuse is #7 in the main fusebox
The 50amp fuse will be in either position #3 or 5 they number from left #1 towards the cartridge fuses
Edited by nige8021
Are you sure thats the right pump? It's listed with a 6R- part number, so for a 2009> car. It could be right if the original part's been superseded, but I'd have thought it should start with 6Q....
I'm not saying it's never the pump, but they don't often go wrong. Was there a fault light on before it failed? Is the garage sure it's getting a good supply of current?
Edited by Yeti
From ETKA
Pretty sure all RHD cars will have got the TRW system.
That 6R0 part number is the current suggestion for this platform.
Just under a grand ÷ VAT from VW. Bargain!
But check the bloody strip fuse first! Even a new genuine pump won't work if that's cracked.
But the old one might if you fit a new fuse.
Edited by Pete1
Yeah, link the strip fuse out with a strand of fuse wire.
Depending on the spec of the car, theres often one or two of the fuses with nothing connected to the other end waiting to get borrowed
