Mk2 86c 1.0 vacuum
I will need some help with the vacuum system. Any scheme will be of help. I did a rebuild but I am not sure of having all the old pipes at their place.
Thanks in advance
  • Views 446
  • Is it the Weber TLA carb? https://www.clubpolo.co.uk/topic/356355-weber-32-tla-carb-vacuum-routing-and-wiring/#findComment-2723489
or Pierburg 1b3?
https://www.clubpolo.co.uk/topic/342127-1990-pierburg-connections/#findComment-2669273
I used the search but for some reason it didn't work. Thanks 👍
I refound it using qwant.com search engine
(no stupid AI or adverts)
tla vacuum layout polo 1.0 86c clubpolo
