Ta technix 4cm (have to lower)
I have the 4cm lowering kit installed, for some reason front seems to be higher than rear.
The ta technix ammo has some kind of regulation ring on the body, but am I obliged to re install the complete front ammo or I will have a chance to lower it with ammo installed?
Thanks in advance for any help
  • Views 544
The fronts lower it by a fixed amount, so you can't change that. You should be able to adjust the rears without taking them off the car
Only the back has the adjustable ring, so
