VW polo mk 2 breadvan 1985
Hi everyone my polo MK2 breadvan 1.05 ltr has a resistance wire from my coil upto my fuse box, but because I am changing the ignition to electronic from points, my electronic ignition requires a full 12 V DC the resistance wire only provides 9 V I but there is a connection from the ignition switch to the fuse box, then it goes from the fuse box to T20 where the black 1.5mm wire changes to a white and Violet wire with a 0.5mm core this happens at T20/6 I need to know where Terminal 20 is ?
  • Views 263
Popular Days
I have looked at the wiring diagram in the manual and there appears to be an inline fuse in the violet and white wire, I am going to remove the outer sleeve to trace the resistor
