Removing side repeaters from mk4
Hi, I have recently bought a pair of clear side repeaters and front indicators. The indicators were no problem to fit but I cant remove the wiring/bulb etc from the orange plastic casing on the repeaters?
Anyone know hot to do this? The indicators you could just pull apart with a bit of twisting/force...etc but not with the repeaters.
thanks
  • Views 1.6k
twist the bulb holder
The side repeaters... mine i just yanked of they're not the bayonet ones. they like squareish.. just pull if thats the case.
Push the actual repeater towards the rear of the car and then pull the front of it out.
Edited by JonDog
  • 9 months later...
i removed mine today by clipping it out but now see no wiring inside the car? is it easiest to go behind the wheel arches to find it? thanks
