Will it pass emmissions??
Hi...
Got Joe's genesis a while back, mot'ed til June 2007, complete with side exit exhaust. I quite like the exhaust, its quite pimp and different. However, come mot time in June, will i need to revert back to standard system to pass emmissions or will it not affect it? I know it doesnt all lie on the side exit (i.e. could fail for other reasons) Just to know in advance, should i put standard back on for mot??
Nick
  • Views 1.7k
Its easier to state that the car has a cat / healthy lambda than the actual design of the system...
If it is pre CAT testing (<pre 92/93 - not 100% :? ) and has a healthy lambda and a CAT anyway it should pass the MOT...
If it is straight through with flames spitting out the side - chances are it'll fail!
LOL
LOL
Its a K- reg 1993, sounds good. I'm going to get my local garage to check the emmision reading just to make sure.
I have a part time job at an MOT Centre.
They can fail you for an exhaust being to loud but the tester has to be a proper nice person
mine got failed for noise! I'm mates with the guy who failed it too! it was fookin loud though g40 with one beetle rear silence fitted as a centre and no backbox = big noise, i liked it though :lol:
i thought they could only fail you on noise if it is of an age to be covered by the eu driveby regulations (mot time comes jus give the tester a score for his pocket normally works to overlook most things ;) )
