polo 9n door speakers
can anyone tell me what size speakers are in the doors of my misses 9n polo, i want to get her new ones for her bday cos one has poped. also if anyone knows how to take the door card off would be great aswell
  • Replies 9
  • Views 7.6k
  • According to Elsawin they are "pop riveted" in place so you need to drill the head of the rivet off Removing and installing front and rear bass loudspeakers Removing Before a loudspeaker can be
6.5"
electric windows or winders?
Edited by Rob123
  • 6 months later...
electric windows...... sorry i just jumped on this 1 but i really wanna know how hard it is :oops:
ther are little screws at the bottom of the door card they r like star size i dont now the exact size. once uve taken those off remove the handle to the door an ther should be 2 big star sized screws. remove all screws an then the door card is stuck on wid door poppers pop them from bottom up and mke sure you disconect the electrics. jsu pull the plug out reli. and jsu watch out for the lock indicator its abit loose jsu mke sure you dont snap it. that should be the door card off realy. if u need any more help jus pm bro.
inabit
personally i would get a new standard speaker mate :) they are only about £12 and they r shit hot, better than most speakers u can buy in halfords or anywhere,unless you get comps and run them off an amp :)
where can you get tehm for £12. thats a bloody bargain
  • 5 years later...
Where from??
  • 3 months later...
I have the same problem and got as far as taking the door card off but can anybody tell me how to get the speaker off?
I can't see any bolts/screws on either side of the speaker and I tried using an allen key in the holes but I can't figure it out?
Removing
Before a loudspeaker can be renewed, the door trim must first be removed. → General body repairs, interior; Rep. Gr.70, → General body repairs, interior; Rep. Gr.70, → General body repairs, interior; Rep. Gr.70.
– Pull connector off loudspeaker.
– Drill out rivets -arrows- using appropriate drill and remove loudspeaker.
Installing
Notet It is essential that all swarf be removed from the door because otherwise corrosion damage will occur.
t Immediately rectify any damage to paintwork caused when drilling out rivets.
– Secure new loudspeaker with commercially available pop rivets of suitable length and diameter.
– Do not forget the rubber ring between trim and loudspeaker when reinstalling the door trim.
Further installation is carried out in the reverse order of removal.
  • 1 year later...
Hey there,
I want to change the factory speakers I have in the front doors in my 9n to after market speakers. As I took off the door card I noticed the factory speakers have been riveted in. How do I remove them and install the after market speakers? What exactly do I have to do?
Thank you
